Booting from SATA CDROM in AOS 5.15.4 LTS (AVH VM) not possible | Nutanix Community
  • January 7, 2022
  • 236 views
  • 24 replies
Hello everybody,
I was unsuccessful to boot from a SATA CDROM in an AHV VM on different Nutanix-cluster with the same AOS 5.15.4 LTS version.
Allthough I explicitly selected to boot from the SATA CDROM, the VM says ‘Could not read from cdrom (Code xxx) and instantly jumps into 2048 game (what the heck).
As soon as I switch to an IDE CDROM, the system boots properly.
Is this a bug in AOS 5.15.4 LTS ?
Didi7
Best answer by Sergei Ivanov
Hi Didi7,
yes, that is a bug in the AOS 5.15.4. The issue is fixed in the AOS 5.15.5 and newer versions. You will have to upgrade both AOS and AHV to get it fixed.
Sergei Ivanov
  • 108 replies
  • January 7, 2022
Hi Didi7,
