PrismCentral - How to label VMs using nCLI? | Nutanix Community
  • November 16, 2021
  • 0 replies
  • 470 views
In my PrismCentral, I am trying to label my VMs so that I can filter on them.   When I try to label the VM, it doesn’t work.  I can create the Labels and I can tag the VM with it but it’s as if the label is not applied to the VM.
Is there a nCLI command that I can use to assign an existing label to a VM?
Be the first to reply!
