I have an error trying to launch the console from a Linux VM. This VM migrated from a Hyper-V cluster to an AHV cluster through Move. I have correctly configured DNS. The VM is on, I can access via SSH.
Could you tell me what else I can verify before opening a case for this issue.PS: I can launch the console of a VM created in the AHV cluster.
Hello @joseparedespy
Can you check if error signatures matches with the article mentioned below.
https://portal.nutanix.com/page/documents/kbs/details?targetId=kA00e000000LJgsCAG
