Can you please describe how failover would occur | Nutanix Community
Hello and thank you for the advice,
I administer 1 block, 3 node cluster on NX-1065-G4 hardware, power is 110v. Following is the software versions:
Version 5.10.10.1 LTS - Pro License
NCC Version: 3.9.4.1
LCM Version: 2.3.2.3.20029
AHV Version: 20170830.396
HA reservation is enabled
Can you please describe, or link to a KB which will help me understand, how a node failure will cause VM fail-over to another node? For instance, if node 1 fails, how and when with the workload fail-over? What configuration settings do I need to consider to optimize the workflow?
Best answer by Bala Murali Krishna
Hi @Adetokunbo
Here is the document link explains three different types of HA configuration on AHV.
AHV | VM High Availability (HA)
BTW, AOS version 5.10.10.1 is out of support and I recommend to upgrade to latest version.
Hi @Adetokunbo
  • October 19, 2021
Splendid, thank you!
Regarding the AOS version, thank you as well. I’ll contact support to identify the best upgrade path / orchestration, since I see the in LCM there are few updates.
