After replacing the motherboard and raid controller, cvm does not start | Nutanix Community
  • October 4, 2021
  • 461 views
After replacing the motherboard and raid controller, cvm does not start. Error "Device 0000:59:0.0 not found..."
Best answer by UPX
Hi Alexey1001,
changing hardware leads to different enumeration for the devices, try this KB and let me know if it helps.
https://portal.nutanix.com/page/documents/kbs/details?targetId=kA00e000000PW2TCAW
Cheers
UPX
  • Outrider
  • 74 replies
  • October 5, 2021
Hi Alexey1001,
Cheers
