Link to Download Nutanix Exam certificates. | Nutanix Community
  • October 3, 2021
  • 1819 views
What is the link to download Nutanix Exam certificates. Earlier there was a link on https://partners.nutanix.com/ which doesn’t work now. Credly.com doesn’t contain pdf certificate.
Please suggest.
Best answer by mikkisse
Hello.
If you received a Credly badge, you can dowload certificate from them.
Just click on your badge - Share (top right) - Cllick on Printer Icon (last in the list) - Download PDF.
maaz
  • 12 replies
  • October 13, 2021
Hello Asif,
Can you please login to https://my.nutanix.com and launch service partner portal and check if you’re able to see exam certificates.
mikkisse
  • 109 replies
  • October 14, 2021
Hello.
  • July 23, 2024
Here you can find your certifications : https://university.nutanix.com/mycertifications
