Playbook Parameters : Created VM | Nutanix Community
  • September 30, 2021
  • 335 views
  • 18 replies
We created a playbook to send email whenever a New VM got created in Nutanix AHV cluster. How can we add User Name and Cluster Name in Email Message? There is not much benefit if,  such details can not be provided,
Event:
Action:
Best answer by Michael.Manuele
@Charu So, unfortunately, the best way to do that today would be adding a REST API action to additional lookup details using the v3/vms API to make the query and then the String parse to pull those details out. We do have an action plan in the next few months that will make it so we can expose these details without needing a lookup, although I don't know if we plan to reveal a username at this time.
Michael.Manuele
  • 47 replies
