Difference between Cluster and I/O latency? | Nutanix Community
  • September 9, 2021
  • 851 views
Difference between Cluster and I/O latency? Is that same or different?
  • 69 replies
  • September 21, 2021
HI Aiyaz,
There are disk I/O Latency, VM Latency, Hypervisor (host) I/O Latencies etc
For more info on I/O latencies on disk, please refer the link below
https://next.nutanix.com/how-it-works-22/disk-i-o-latency-on-a-nutanix-cluster-38349
Hope this helps
