Can I use Nutanix Volume Group on DX series equipment? | Nutanix Community
The Nutanix AOS/AHV was installed on the DX equipment, and the ISCSI Data Services IP was also set up. The Volume Group tab and create Volume Group  are not visible in the Prism - Storage - Table.
AOS version is 5.20.x
Is Volume Group not supported for DX equipment? Or do I need another setting after AOS 5.20?
Best answer by UPX
I’ve found the issue.
there was an error appling licenses,
It seems, with starter edition, you can manage VGs only via acli not via GUI.
After i reapplied the licenses correctly everything works as expected.
Hope it helps.
UPX
  • Outrider
  • 74 replies
  • December 4, 2021
I got the same problem, volume group tab missing and +volume group missing
i can only interact with volume groups via cli
AOS 5.20.2.1 with AHV setup on a HPe DX8000 3 nodes cluster
UPX
  • Outrider
  • 74 replies
  • December 5, 2021
Hope it helps.
