Want to know about api version deprecated roadmap | Nutanix Community
Hello
i am a developer who develops through nutanix api
i Want to know about api roadmap
i found out by chance that url
https://www.nutanix.dev/2019/01/15/nutanix-api-versions-what-are-they-and-what-does-each-one-do/
when i read that page, i feel curious about api roadmap in nutanix
      1. when v2.0 api is advanced, v0.8 or v1.0 is deprecated?
      2.  when i want to use migrate or snapshot function, i have to use v0.8 api?
  1.  will some functions(like migrate) continue to be categorized in v0.8, v1.0 and v2.0?
and if i get some document about v0.8 api, i want to get them
i wait for your answer
thank you
Chaitrali Deshpande
Hello @hoseong ,
Thank you for posting your question. I have reached out to the api team and I will check with them about this. Thank you for your patience.
Chaitrali Deshpande
  • July 30, 2021
thanks i wait for your reply
but, can i ask one more question about Nutanix Solution API?
i want to know that
Are each Nutanix Solution API like ERA API, FILES API, CALM API compatible with low version api?
thank you
