Hello all,
I need some help in finding my Nutanix Certificate because my employer needs it. They don’t use badges or transcripts from Credly. Where do I download the certificate?
Hello all,
Best answer by Chaitrali Deshpande
Hello
You can download it on portal:
https://nutanix.portal.relayware.com/?eid=Certificates
But it will be available within 7 days after certification.
You will also receive email notification about readiness of your cert.
Chaitrali Deshpande
