What is the best practice for allocating storage? | Nutanix Community
What will be total usable space for the hypervisor and best practice to allocate the storage.I have three new Nutanix nodes. Physical capacity of Cluster is 79.04 TB and Free logical is 39.52 TB in RF2.
Best answer by Alejandro Suarez
Hello @SinghK
Not sure If you got this sorted already but I figured I would answer.
If you haven’t modified the Advertised capacity of your storage containers, then the theoretical usable capacity would be the available logical space in the storage pool of the cluster (minus 10 % approximately of the space accounted for garbage collection).
So in your case the theoretical usable capacity would be approximately 35 TB.
That usable capacity doesn’t account for storage resiliency in case of a node failure so if you want to take that part into account too then you can follow the next KB to get a rough estimation of how much space you can use in your cluster and still tolerate a node failure: Recommended guidelines for maximum storage utilization on a cluster
Hope this helps.
Alejandro Suarez
Hello @SinghK
Hope this helps.
  • June 17, 2021
Thanks !
Is cache is enabled on the storage containers ?
  • 69 replies
  • June 25, 2021
Hi SinghK,
Let me answer this question.
Cache Deduplication is not enabled by default on the Storage containers.You can enable cache deduplication of read cache to optimize performance. Cache deduplication means deduplication performed on the data in memory.
For more information, please refer: Cache Deduplication
Hope this helps
