I will upgrade AOS version from 5.10.6 to 5.15.5 on Dell XC640 that hypervisor version is vSphere6.7 U2.Can I rollback AOS version If upgrade process occurs any trouble? Please give me any manuals if do you know that.
AOS upgrade from 5.10.6 to 5.15.5 Can I roll back ?
Best answer by Sergei Ivanov
There is absolutely no supported way to rollback the AOS version. If you encounter any problems during the upgrade process, please, open a support ticket and the problem will be resolved by our engineers.
