Changing default gateway for CVM/AHV | Nutanix Community
  • March 31, 2021
  • 5217 views
Hi everybody,
We’re doing a slight restructure in our DC and in thus need to change the default gateway used by a Nutanix cluster (3-node cluster).
I’m aware of the following guide:
https://portal.nutanix.com/page/documents/details?targetId=Advanced_Admin-Acr_v4_6:ip__ip_reconfig_web_c.html
But isn’t it at all possible to change something as simple as just the Default Gateway without such an invasive procedure requiring downtime?
The part of the article on how to do it manually is...Non-existent:
https://portal.nutanix.com/page/documents/details?targetId=Advanced_Admin-Acr_v4_6:ip__cvm_ip_address_reconfigure_t.html
Best answer by Chaitrali Deshpande
Hello @Mikael Dyreborg Hansen
Thank you so much for posting your question. There is a way without downtime, but our team hasn’t suggested using it for now. They are working on some solution but for now, they recommend using the method mentioned here:
https://portal.nutanix.com/page/documents/details?targetId=Advanced-Admin-AOS-v511:ipc-cvm-ip-address-reconfigure-t.html
Chaitrali
Chaitrali Deshpande
Chaitrali
