We have two Prism Central in our environment. Is there a way to link two PrismCentral ?
Interconnect Two Prism Central, is it possible?
Best answer by Chaitrali Deshpande
Hello
Thank you for posting your question. Unfortunately, we do not have any way to link two PC. That’s not possible. May I know the reason for linking the two Prism Central? Please reply to me with a detailed use case that you are trying to achieve.
Chaitrali Deshpande
