Custom Created Network IP Fluctuating in Android x86_64 VM | Nutanix Community
  • March 9, 2021
  • 56 views
I created a custom network(does not have internet access) in PC and assign it to an android vm but its fluctuating. It is not connecting to that network. (Also tried by creating  diffrent subent, same issuse ).
While this issue occurs only in Android Vm, Not in Linux,Windows VM.
Linux and Windows VM were easily connected without any issue.
See GIF for more clarification.
Best answer by Sudhir9
Hello @Balram
Thank You for your question to Nutanix Communities. It's not clear from the description if you have assigned static IP to this Android VM or It is supposed to get Automatic IP from DCHP / IPAM.
If it needs automatic IP and you have not already tried enabling IPAM on the network you have created in PRISM for this VM, please try enabling IPAM and see if that helps to assign a valid IP to this VM. Below is the link for AHV Network Overview from AHV Networking GUIDE, it explains the IPAM feature and how to configure it.
Sudhir9
  • 62 replies
  • March 15, 2021
Hello @Balram
