If the clusters are related with prism central (so I should use v3), Can i use v2 to actions like: manage NIC, Attach/Detach Disks, manage snapshots from API v2?
Is recovery plans is the same as snapshots here? I want to create jobs for automatic snapshots, but I do not see thios possibility in v2
I am using the same account for api v2 and v3 actions, in production environment with my own IP, it will be the same host? It is specified in API Documentation, but I want to be sure if the host for both will be the same - eg. nutanixtest.com/v2… and nutanixtest.com/v3…
Thanks!
API V2 vs V3
Best answer by Alona
Hi AndMG,
PC works with APIv3 only. You can still use v2 and even v1 but the calls would have to be directed at PE instead of PC.
A recovery plan is similar to a snapshot schedule in that it is a DR tool that enables you to protect VMs between sites. A recovery point is a similar term to the snapshot.
You can add a snapshot schedule with APIv2 post /protection_domains/{name}/schedules.
Let me know if that helps.
