Server 2019 Hyper V with Nutanix ? | Nutanix Community
  • February 18, 2021
  • 3763 views
Muhammed Ashraf
Please advise me is it support Server 2019 Hyper V on Nutanix? I unable to Find the article on Nutanix Portal with server 2019? I am planing to migrate from Server 2012 hyper v failover cluster to 2019 Server Hyper V failover Cluster? Which AOS Version is support Server 2019?
Best answer by Alona
Hi Muhammed,
Nutanix Compatibility matrix has Hyper-V 2019 in the drop-down of the hypervisor field. If you select that option then you will see available hardware and AOS versions (5.18 and 5.19). Let me know if that answers your question, please.
  • February 19, 2021
Hi Muhammed,
Muhammed Ashraf
Hi Alona,
Thank you for reply
is there any installation document with server 2019, I can able find document with server 2016.
  • February 19, 2021
This is the latest Hyper-V Administration for Acropolis Guide if that’s what you meant.
Muhammed Ashraf
Yes but it is only mentioned server 2016.
not for 2019
i am looking for 2019 hyperv administration documents
  • February 19, 2021
The guide is not specifically for Hyper-V 2016. It says the version must be at least 2016. Use the latest Foundation and follow the latest Field installation guide.
