Contact (bare metal image) when adding new nodes. | Nutanix Community
  • February 3, 2021
  • 209 views
We are planning to add new nodes to existing clusters.
Before the extension, proceed with the new Node AOS install (Bare metal image) and then add.
At this time, I want to know if there is no problem if the existing cluster AOS and the new AOS are different versions.
ex) Existing Cluster AOS 5.10.9 / New Extension Node AOS 5.15.x
Please give me some advice.
Thank you.
  • February 4, 2021
Hi yhcho,
When the cluster discovers the CVM on the node it will image it to match the rest of the cluster if necessary during cluster expansion. Take a look at Prism Web Console Guide: Conditions for Cluster Expansion
