Cannot add target cluster to X-ray | Nutanix Community
  • February 3, 2021
  • 329 views
Forum|alt.badge.img+17
I am using the newest version of X-ray (3.10.0) to connect to a vCenter (6.5U1d) to have some performance tests for my cluster. At the step 4 (Validation) of creating the target cluster, it failed to validate the cluster.
Error: Target cannot be verified.
After looking into the log, in the HTTP Response body, it contains the 500 Internal Server Error. Still cannot get what it means as everything seems fine and the connection from X-ray VM to cluster still has no problem at all.
Best answer by cwilson
It’s difficult to say what the issue is without more specific error details from the logs or elsewhere. That said, the 3.10.1 version of X-Ray was released just a bit ago with a number of fixes for issues found during cluster discovery. It’s possible it might include a fix for your issue.
Forum|alt.badge.img+10
  • February 8, 2021
