Can I change IP or VLAN in IPMI after Foundation that will be concern or affect to AHV environment?
Changing IP Or VLAN In IPMI After Foundation
Best answer by Alona
IPMI interface is independent by nature hence there will be no issues in changing IPMI VLAN or IP address. Look at this article as a reference KB-1091 Common BMC and IPMI Utilities and Examples (look for “Determine and modify current LAN settings”).
