Prism Central VM efficiency measurement/inefficient VMs no longer working | Nutanix Community
  • December 15, 2020
  • 1764 views
Hello, all. We’ve had our Nutanix cluster up for all of a month, and I just noticed our Prism Central instance is no longer reporting any inefficient VMs in the cluster (whereas just a week or two ago it had started to accumulate a list of VMs it had decided were overprovisioned or bullies).
And when I look at a particular VM, on the main properties page it shows “Efficiency - MeasurementDisabled.”
Can anyone tell me why this might happen? Thank you.
  • December 17, 2020
Hi JAC_Brian,
Is it possible that someone disabled it?
  • December 17, 2020
Yes, it’s possible, however, when I try to re-enable the efficiency measurement, it doesn’t work. It goes through the motions and shows that it succeeds in the task, but it’s still disabled for the VM when you back to look at it.
Interestingly, I see that Prism Central has a new version that was just released with fix ENG-337894: “The VM Efficiency reports the status of Overprovisioned, Constrained, and Bully as NA. Also, the dashboard for VM Efficiency is reported as 0.”
That sounds like it addresses this very problem.
  • December 18, 2020
Now, that the additional details are revealed, it does sound like you found the right ENG. If the upgrade does not fix the issue consider logging a support case.
