Keycloack operator/PotgresSQL permission denied | Nutanix Community
  • December 14, 2020
  • 869 views
Hello everyone,
I'm having some trouble using the keycloak operator installing on a simple Kubernetes Cluster on Karbon
Basically, what happens is that when I install a new Keycloak, the PostgresSQL is not able to run properly because it does not have permissions to create a new directory on /var/lib/pgsql/data/userdata
As far as I understood, the problem is related to the securityContext which is not set to the postgres deployment even if Postgres runs always using user 26 (as can be noted here: https://catalog.redhat.com/software/containers/rhscl/postgresql-10-rhel7/5aa63541ac3db95f196086f1?container-tabs=dockerfile)
I had to do a lot of workarounds to make it work, and finally I succeded by configuring manually the security context as follows:
securityContext:
  fsGroup: 26
  runAsUser: 26
There is any possibility to set the security context via the operator? if not, can you please point me out what is the correct solution to apply?
vshuguet
  • 19 replies
  • December 15, 2020
Hello @Cecia ,
Welcome to the Karbon Clusters community!
The issue you mention above doesn’t look like it would be specific to a Kubernetes cluster deployed by Karbon Clusters.
As far as I know, you should be able to pass those settings (the whole securityContext YAML block) in the Operator manifest (the YAML file you apply via “kubectl -f apply” to create that Operator object) and it is the job of the Operator to pick it up and honor the setting.
Hope it helps,
Best regards,
Sylvain Huguet
