Phoenix failed to run on G3 platform | Nutanix Community
  • December 3, 2020
  • 422 views
Forum|alt.badge.img+17
I have an old G3 block that need to be installed for a demo.
And after lots of failed tries from Foundation installation, I ended up installing the node manually. But unluckily after creating phoenix iso file for AOS installation and mounting it to the node, an error occurred with message below:
“Unable to match system information to layout module”
Has someone seen this happened before?
Hi , G3 is EOL (End of Life) , if you try to image your nodes with foundation 4.5.4.2 or lower then it will work , because its EOL in latest version of foundation
