upgrade Hyper-V 2012R2 to 2016 on XC630 | Nutanix Community
  • November 26, 2020
  • 390 views
Sayo
  • 7 replies
Hi,I am always taken care.
I'll upgrade Hyper-V 2012R2 to 2016 on XC630 so I have some questions.
・metadata(json) download from Nutanix Portal. Can I do that Hypervisor ISO file there ?
・What difference are metadata(json)  each ?
・Use Hypervisor ISO file of Evaluation version, is it OK?
・ISO's language adapt any languages? or English only?
Sincerely,
Best answer by Sudhir9
Hello @Sayo
Thank you for your questions please see the answers below.
・metadata(JSON) download from Nutanix Portal. Can I do that Hypervisor ISO file there?
   ISO file you need to download from VLSC or MSDN.
・What difference is metadata (json)  each?
JSON only have 1 version of Hyper-V ISO each based on your downloaded ISO. The JSON file usually matches 1 of the ISO files available oim MSDN / VLSC.
Not supported.
All available language in the ISO. Depends which ISO you download from MSDN,.
Regards
Sudhir
Sudhir9
  • 62 replies
  • November 26, 2020
Hello @Sayo
Not supported.
Regards
Sudhir
Sayo
  • 7 replies
  • November 30, 2020
@Sudhir9
Thank you so much for your kindly reply.
I refer to your statement.
Sudhir9
  • 62 replies
  • November 30, 2020
@Sayo
Thanks for the update please let me know if you have any follow-up questions.
