AsyncDR need vCenter? | Nutanix Community
  • November 18, 2020
  • 199 views
Sayo
  • 7 replies
I use vSphere6.0 U3 on NX series and set AsyncDR replication to AWS.
Some protection domain’s AsyncDR are errorred after VCSA has broken and re-deploy.
Are AsyncDR and vCenter  depend on each ?
Sincerely,
Best answer by Paul Ilavarasu
We depend on vcenter, that is where all the API calls are made after it is registered.
Refer this guide
https://portal.nutanix.com/page/documents/details?targetId=Prism-Element-Data-Protection-Guide-v511:sto-pd-guidelines-r.html
Refer this guide
Sayo
  • 7 replies
  • November 26, 2020
Thank you for your reply.
I understood that.
