Create VM in specific Container | Nutanix Community
  • October 22, 2020
  • 8 replies
  • 723 views
I can't find how to specify on which container the disk should be created,
can you help me?
here is my json.
{"spec": {
     "name": "TEST-API",
     "resources": {
       "power_state":"OFF",
       "num_vcpus_per_socket": 1,
       "num_sockets": 1,
       "memory_size_mib": 8192,
       "disk_list": [
          "device_properties": {
            "disk_address": {
              "device_index": 0,
              "adapter_type": "SCSI"
            "device_type": "DISK"
          "disk_size_mib": 8192
            "disk_address": {
              "device_index": 0,
              "adapter_type": "IDE"
            "device_type": "CDROM"
       "nic_list":[
           "nic_type": "NORMAL_NIC",
           "is_connected": true,
           "ip_endpoint_list": [
               "ip_type": "DHCP"
           "subnet_reference": {
             "kind": "subnet",
             "name": "VLAN-130",
             "uuid": "002e2b71-a8ca-4360-86e1-0934aa9035f5"
       "guest_tools": {
         "nutanix_guest_tools": {
           "state": "ENABLED",
           "iso_mount_state": "MOUNTED"
     "cluster_reference": {
       "kind": "cluster",
       "name": "AA01CLUAHV001",
       "uuid": "0005a425-7396-e383-451d-246e960fb6d0"
   "api_version": "3.1.0",
   "metadata": {
     "kind": "vm"
Cirvent
Best answer by Alona
You have at least two places to look for the specs when it comes to APIs:
Nutanix Dev portal (as UPX pointed out earlier)  and
Prism REST API Explorer (only PC has option to browse API v3)
For example:
Nutanix Dev portal:
REST API Explorer:
UPX
  • Outrider
  • 74 replies
  • October 23, 2020
Hi Cirvent,
Not sure if i understand your question but you should be able to that easily using acli via ssh on a cvm
acli vm.disk_create <VM-Name> container=<Container-Name> create_size=<Disk-Size>
Hope it helps
  • October 23, 2020
Hi @UPX
My problem is that when I create a VM the disk is stored in the wrong container.
UPX
  • Outrider
  • 74 replies
  • October 23, 2020
cirvent wrote:
Hi UPX,
my problem is that when I create a VM the disk is stored in the wrong container.
If there are no data on disk you can simply delete the original one and create the new one on desired container
Otherwise, If you have data on disk you can create the new one cloning the old but this time on the right container
  • October 23, 2020
It is not possible to create the VM with its disk on the right container?
UPX
  • Outrider
  • 74 replies
  • October 23, 2020
Of course you can.
You can select the container to store the disk when you add the new disk to the vm via gui.
Or you can do the same via acli or via api
  • October 23, 2020
I have no problem in GUI, only via API , What should I add to the json file, to indicate the correct container?
UPX
  • Outrider
  • 74 replies
  • October 23, 2020
Ok via API, now it’s clear.
You will find all the body content specs here: https://www.nutanix.dev/reference/prism_central/v3/api/vms/postvms/ or here https://www.nutanix.dev/reference/prism_element/v2/api/vms/post-vms-createvm/
Hope it helps
  • November 5, 2020
For example:
Nutanix Dev portal:
REST API Explorer:
