Trying to find info regarding ESXi6.7 NVMe device support within AOS. | Nutanix Community
  • October 8, 2020
  • 239 views
We have a 15 block HPE environment built with AOS 5.15.2. we need to enable flash mode on a NVMe device (vmdk) which is presented within vSphere but cannot be seen via prism element under the VM vDisks or via ssh shell to cvm’s is this feature not currently supported? any ideas I am struggling to find much on the support portal?
still unsure on this how do we pin the NVMe vmdk to the performance tier
cheers
  • 69 replies
  • October 8, 2020
Hi GraemeW,
I found the best practices for the Fash mode
https://portal.nutanix.com/page/documents/solutions/details?targetId=BP-2031-Flash-Mode:BP-2031-Flash-Mode
Hope this helps.
I will do a bit more research on NMes
Thank You
