I have one CVM out of space in /home, I have seen that I have the file localhost_access_host.txt with almost 20GB.
Could I rotate or delete this file?
In another CVM I don’t see this file.
Antonio Maeso
Antonio Maeso
Best answer by Alona
Hi AntonioM,
There is an article on KB-8561 Prism Central/Prism Element upgrade failing with /home space constraints due to localhost_access_log.txt files not rotating. It explains the issue and provides a temporary solution as well as a fix. Instead of deleting the file it suggest to zero out the log file to reclaim the space on the CVM.
Alternatively, there is also a post on this CVM Non-Root Partitions Space Usage High - clear space safetly.
Let me know if this is helpful.
