Hello
after reinstalling Prism Central (PC) from v.5.16.1.3 to v5.17.1.1, using the procedure for unregistering PC
Unregistering cluster from PC
https://portal.nutanix.com/page/documents/details?targetId=Prism-Central-Guide-Prism-v5_5:mul-vcenter-server-unregister-pc-t.html
we have some strange issues:
- A PC REST API query return 2 available cluster (one for PE and one for PC, with different uuid on metadata)
It is normal for API 3.1?
- On Nutaniy API Explorer a simle query of vms "POST /vms/list"
With small payload for "get_entities_request"
"kind": "vm",
"length": 10,
"offset": 0
returns
"api_version": "3.1",
"code": 500,
"message_list": [
"message": "Internal Server Error. Failed to get schema for cluster 000597eb-aa13-1c72-0000-000000029cf0",
"reason": "INTERNAL_ERROR"
"state": "ERROR"
Where the displayed uuid is the correct PE cluster uuid.
This is a lab cluster, then we have just one culster with < 50 Vms
Any suggestion?
