How to change GPU mode on AHV Cluster | Nutanix Community
  • August 10, 2020
  • 1343 views
I have a Nutanix Node - Dell XC740xd with 4 Tesla T4 GPUs installed.  I am Running AOS 5.15.
It seems my GPU is in passthrough mode, and I would like to switch this to vGPU mode.  Does anyone know how to do this?
             "status": "UNUSED",
              "assignable": true,
              "vendor": "NVIDIA",
              "name": "Tesla T4 compute",
              "index": 0,
              "max_resolution": "None",
              "num_vgpus_allocated": 0,
              "pci_address": "0000:86:00.0",
              "fraction": 0,
              "mode": "PASSTHROUGH_COMPUTE",
              "num_virtual_display_heads": 0,
              "guest_driver_version": "None",
              "frame_buffer_size_mib": 16384,
              "device_id": 7864
Best answer by Alona
Hi GeoB,
Have you seen this guide? It goes over limitations, driver installation and configuration.
Let me know if you need more info.
  • August 11, 2020
Hi GeoB,
  • Outrider
  • 75 replies
  • August 18, 2020
Have you used the gpumodeswitch command?
Although you have T4’s our GPUs needed this as they initially shipped in Compute Mode and the newer ones came in Graphics Mode.
Get the gpumodeswitch package and give it a try and let us know...
