2 all-SSD + 5 SSD+NVMe nodes in RF3 cluster - recommended? | Nutanix Community
Hi team,
We have a 5 node SSD+NVMe cluster with RF3 and are considering adding 2 all-SSD nodes to that cluster.
Are there any drawbacks/risks/restrictions to having only 2 nodes of all-SSD type in this RF3 cluster?
SSD+NVMe nodes:  G7, 6256 CPU, 1TB RAM, 4x1,92TB SSD, 4x3,84TB NVMe
All-SSD nodes: G6, 6128 CPU, 768GB RAM, , 6x3,84TB SSD
Best answer by Paul Ilavarasu
Yes, Condition remains same , You will have to meet the RF for both NVMe and SSD nodes , Hybrid model approach apply to NVMe.
For an Assistance , Create a ticket on nutanix support
Nutanix supports mixing nodes that contain NVMe drives in the same cluster with all-SSD nodes that do not contain NVMe drives.
Refer below URL
https://portal.nutanix.com/page/documents/details/?targetId=Hardware-Admin-Ref-AOS-v5_16:har-product-mixing-restrictions-r.html
  • August 6, 2020
Paul Ilavarasu wrote:
Refer below URL
Hi Paul,
many thanks!
We referred to this doc before, however it only mentions the minimum required number for Hybrid-AF environments:
“You can mix all-SSD nodes and hybrid SSD/HDD nodes in the same cluster only under the following conditions:
  • Mixed all-flash/hybrid clusters must have a minimum of two all-SSD nodes.
  • The minimum number of each node type (all-SSD/hybrid) must be equal to the cluster redundancy factor. For example, clusters with a redundancy factor of 2 must have a minimum of two hybrid and two all-SSD nodes.”
It is not completely clear if it applies to our case with 2 SSD-only+5 SSD+NVMe nodes
