Remove Zombie VMs from Prism Central | Nutanix Community
After connecting my Cluster to Prism Central I see some VMs in Prism Central that are not existing anymore in the Cluster and I cannot find a way to remove them. Here is an example:
These VMs are already deleted in the cluster
In Prism these VMs are not visible
Is there a way to delete these VMs from PC? I already tried to remove the cluster from PC, run the cleanup scripts and connect to PC again (even to a new installed one), but it did not help.
  • 22 replies
  • July 9, 2020
Hello @MichaelAhn!
Could you confirm the hypervisor you are running on? Please share additional environment details like PC version, Cluster(AOS) version, Hypervisor version etc.
Did you recently perform any activity like hypervisor conversion, PC upgrade etc?
Additionally, where is the Prism Central VM deployed? Is it on the clusters managed by this PC or on different environments.
Cheers!
Nashma
  • July 9, 2020
Hi @Nashma
The cluster is running on
AHV (Version Nutanix 20190916.158 )
AOS 5.16.1.2
PC  5.17.0.3 (running on the cluster)
I did no hypervisor conversion.
  • July 13, 2020
Hi MichaelAhn,
I would suggest opening a case with Nutanix Support.
