How may I find a VMs UUID in Prism Central? I am using PC 5.16.1.2
Thanks in advance,
GeoB
Thanks in advance,
GeoB
Best answer by bdiener
I’m not sure how to do it in Prism Central specifically but in “normal” Prism you can simply go to your VM listing, Table View (upper left), then click to highlight one of your VM’s. If you scroll down you should see an “ID” value on the left summary.
Alternatively - you can get the UUID by SSH’ing into a CVM and running acli vm.list
