Adding NIC driver to Phoenix.iso | Nutanix Community
  • June 9, 2020
  • 1721 views
Is there a way I can inject a NIC driver into the Phoenix.iso?  We use a Broadcom 10Gb and the firmware file is not present on the Phoenix.iso so it can’t load the nic’s.
Alejandro Suarez
At the moment there is not an option to inject drivers onto the phoenix ISO, you will need to use your Hardware specific vendor method to install the drivers for the Broadcom NIC in the nodes.
