AOS update with resilience issue | Nutanix Community
We have a cluster with 4 nodes and I will perform the update from 5.9.4.2 to 5.10.10.1.
a some minutes ago, I see that my cluster have a disk space problem and the resilience board is red with the “not resilience” information.
In this case I will have a problem when perform the AOS upgrade? I not have time to resolve the space issue now…  Please, send me any information.
Best answer by HITESH0801
Hey @Ismael.pereira
If your home partition is above the threshold, you can use the following KB
portal.nutanix.com/kb/1540
Regarding AOS upgrade issue, before performing an AOS upgrade, there’s something called pre-upgrade which runs a series of checks to ensure everything will be fine when you’ll move forward with an AOS upgrade.
HITESH0801
  • 104 replies
  • June 3, 2020
Hey @Ismael.pereira
Thanks man… I performed the pre-check and no issues… I will perform the upgrade tomorrow and will post result. Many thanks!!
