Change IP address of Prism Central 5.16.2 | Nutanix Community
  • May 27, 2020
  • 3779 views
I need to move the PC VM to a different cluster and want to change the IP address of PC. I cannot find a description for version 5.16, only a very old one for version 4 that does not work.
I also tried the instructions from https://portal.nutanix.com/page/documents/details/?targetId=Advanced-Setup-Guide-AOS-v5_16:ipc-cvm-ip-address-reconfigure-t.html but it does also not work. After reboot VM ip address is still the old one.
Is there a description how to do it with PC 5.16?
Best answer by Alona
Hi @MichaelAhn
The procedure you are following is for re-IP for CVMs, not the PC VMs, that’s why it does not yield the desired outcome.
The process of changing PC VM IP address does exist however at the moment it is not shared with the general public hence I’d suggest opening a Support Case. On support ticket, provide the current PC version, if is running on ESXi or AHV, and if on AHV if it is using managed or unmanaged network.
  • June 1, 2020
Hi @MichaelAhn
