Veeam backup and data protection | Nutanix Community
I am backing up with veeam in nutanix cluster. I use esxi 6.5 on nutanix cluster
I also replicate to remote office with some virtual machines with data protection. and backup of the same virtual servers with veeam.
Is there a limit here or this building is made right. both are using the same snapshot. Would it be a problem if replication starts with veeam backup at the same time
  • May 8, 2020
Hi Dotex,
What kind of limit do you mean?
I would spread backup operations in time. Worst case scenario read operations will be queued but that does not help with the read of the data nonetheless.
Also, I would make certain that it is the same snapshot file that is being replicated or that the snapshot files are rotated frequently enough to avoid piling up and cause latency on the parent VM. From what I know a backup solution normally does a call to take a snapshot first and then copies it across to the desired destination. The more snapshots a VM has (the longer or deeper the snapshot tree is) the higher is the latency to read/write from/to the VM’s disk. Therefore it is beneficial to keep your snapshot list for a VM short and fresh i.e. with no old snapshots.
Please let me know if that is helpful.
  • May 29, 2020
thanks
