Move migration time block exclude | Nutanix Community
  • April 29, 2020
  • 2624 views
I have a question, is it possible to exclude a timeblock from syncing?
We want to migrate a machine, wich may not delay in the nigthly schedules. We are now running version 3.4.1
Best answer by jlaunier
Hi @Bart-Wessels , the fundamentals are in place to support this but it is not implemented as a feature in the GUI.  You could achieve this now if you called Move APIs from a script to pause/resume the migration at certain times based on an external scheduler such as a cron job.  If you are interested in this type of approach, I can get you access to some sample scripts.  We have plans to add such sample scripts to our developer.nutanix.com portal but these are not live yet.
Forum|alt.badge.img+9
  • 26 replies
  • April 29, 2020
