Metrics explained | Nutanix Community
Metrics explained
  • February 26, 2020
  • 2525 views
Hi All,
I am pulling some data with the API.
For example https://MYIP:9440/PrismGateway/services/rest/v2.0/hosts
Results with , among other metrics, the following.
Where can I find an explanation of each metric?
            "stats": {
                "hypervisor_avg_io_latency_usecs": "0",
                "num_read_iops": "319",
                "hypervisor_write_io_bandwidth_kBps": "0",
                "timespan_usecs": "20000000",
                "controller_num_read_iops": "696",
                "read_io_ppm": "641128",
                "controller_num_iops": "1588",
                "total_read_io_time_usecs": "-1",
                "controller_total_read_io_time_usecs": "196391465",
                "hypervisor_num_io": "0",
                "controller_total_transformed_usage_bytes": "-1",
                "hypervisor_cpu_usage_ppm": "60000",
                "controller_num_write_io": "17846",
                "avg_read_io_latency_usecs": "-1",
                "content_cache_logical_ssd_usage_bytes": "0",
                "controller_total_io_time_usecs": "1047534860",
                "controller_total_read_io_size_kbytes": "1001929",
                "controller_num_seq_io": "-1",
                "controller_read_io_ppm": "438363",
                "content_cache_num_lookups": "239917",
                "controller_total_io_size_kbytes": "2031200",
                "content_cache_hit_ppm": "523118",
                "controller_num_io": "31775",
                "hypervisor_avg_read_io_latency_usecs": "0",
                "content_cache_num_dedup_ref_count_pph": "100",
                "num_write_iops": "178",
                "controller_num_random_io": "0",
                "num_iops": "497",
                "hypervisor_num_read_io": "0",
                "hypervisor_total_read_io_time_usecs": "0",
                "controller_avg_io_latency_usecs": "32967",
                "num_io": "9959",
                "controller_num_read_io": "13929",
                "hypervisor_num_write_io": "0",
                "controller_seq_io_ppm": "-1",
                "controller_read_io_bandwidth_kBps": "50096",
                "controller_io_bandwidth_kBps": "101560",
                "hypervisor_num_received_bytes": "0",
                "hypervisor_timespan_usecs": "60000000",
                "hypervisor_num_write_iops": "0",
                "total_read_io_size_kbytes": "473896",
                "hypervisor_total_io_size_kbytes": "0",
                "avg_io_latency_usecs": "1749",
                "hypervisor_num_read_iops": "0",
                "content_cache_saved_ssd_usage_bytes": "0",
                "controller_write_io_bandwidth_kBps": "51463",
                "controller_write_io_ppm": "561636",
                "hypervisor_avg_write_io_latency_usecs": "0",
                "hypervisor_num_transmitted_bytes": "0",
                "hypervisor_total_read_io_size_kbytes": "0",
                "read_io_bandwidth_kBps": "23694",
                "hypervisor_memory_usage_ppm": "247304",
                "hypervisor_num_iops": "0",
                "hypervisor_io_bandwidth_kBps": "0",
                "controller_num_write_iops": "892",
                "total_io_time_usecs": "17425915",
                "content_cache_physical_ssd_usage_bytes": "0",
                "controller_random_io_ppm": "-1",
                "controller_avg_read_io_size_kbytes": "71",
                "total_transformed_usage_bytes": "-1",
                "avg_write_io_latency_usecs": "-1",
                "num_read_io": "6385",
                "write_io_bandwidth_kBps": "31376",
                "hypervisor_read_io_bandwidth_kBps": "0",
                "random_io_ppm": "-1",
                "total_untransformed_usage_bytes": "-1",
                "hypervisor_total_io_time_usecs": "0",
                "num_random_io": "-1",
                "controller_avg_write_io_size_kbytes": "57",
                "controller_avg_read_io_latency_usecs": "14099",
                "num_write_io": "3574",
                "total_io_size_kbytes": "1101416",
                "io_bandwidth_kBps": "55070",
                "content_cache_physical_memory_usage_bytes": "16144387132",
                "controller_timespan_usecs": "20000000",
                "num_seq_io": "-1",
                "content_cache_saved_memory_usage_bytes": "0",
                "seq_io_ppm": "-1",
                "write_io_ppm": "358871",
                "controller_avg_write_io_latency_usecs": "47693",
                "content_cache_logical_memory_usage_bytes": "16144387132"
Best answer by HITESH0801
Hello @Sammy777
The following article provides a description of many alert metrics.
https://portal.nutanix.com/#/page/docs/details?targetId=Prism-Central-Guide-Prism-v5_16:mul-alerts-user-created-metrics-r.html
Let me know if it helps!
HITESH0801
  • 104 replies
  • February 26, 2020
Hello @Sammy777
