CPUPower Command Missing | Nutanix Community
  • February 14, 2020
  • 1091 views
  • 12 replies
Hi, NCC is reporting that I’m missing the cpupower command. Seems strange. I’m using a i7-2600k processor in each node. Should I install the package using yum repositories?  Where does it run, host or CVM?
Detailed information for host_cpu_frequency_check: Node 192.168.0.127: ERR : Error while getting host CPU frequency range. bash: cpupower: command not found   Node 192.168.0.121: ERR : Error while getting host CPU frequency range. bash: cpupower: command not found   Node 192.168.0.125: ERR : Error while getting host CPU frequency range. bash: cpupower: command not found   Node 192.168.0.123: ERR : Error while getting host CPU frequency range. bash: cpupower: command not found
Best answer by Jubran
Are you running a Dell R640 node?
This is expected behavior on these nodes when running NCC 3.5.x due to a driver limitation preventing the 'cpupower' data from being collected by NCC.
If that’s the case then you can upgrade NCC or disable this specific check:
  • Go to Prism
  • Health tab
  • Search for Host CPU Frequency Check
  • Go to the check and Select Turn Check Off
You can check out KB-5542 for more information about this check on all hardware.
Jubran
  • 19 replies
  • February 14, 2020
  • Go to Prism
  • Health tab
