QCOW2 disk file for Nutanix Move VM | Nutanix Community
  • February 12, 2020
  • 3938 views
I am new in Nutanix Move can anyone help me to deploy it in PrismElement using QCOW2 disk file. Also I don’t have that disk file, please help to create it.
Best answer by JeremyJ
Hello @Vignesh_Sk
The Move VM disk is not created on the cluster. It can be downloaded from the portal as part of the ZIP file for AHV.
As @PDAABI  noted, the deployment instructions are in the documentation linked there. Please have a look and update here if you still have questions.
PDAABI
  • Trendsetter
  • 54 replies
  • February 12, 2020
Hi @Vignesh_Sk
This is documented in the Move User Guide. Of course you need to be able to logon to my.nutanix.com to access the document.
JeremyJ
  • 77 replies
  • February 28, 2020
Hello @Vignesh_Sk
