Please fix the NCC Check for I9-9900 CPU after upgrade | Nutanix Community
  • February 11, 2020
  • 895 views
mshanley
3 Identical pc's P300 Lenovo running I-9900 Cpu's
error back saying non intel CPU
Best answer by Stalin.Stepin
Hi @mshanley. Thanks for reaching out to us and yes, support reads the posts users post on this community :)
To fix this, I request you to kindly open a case with us so that we can collect a few more information and raise a bug with engineering to get this fixed. Kindly upload the output of the following commands to the case as well while opening the ticket.
NCC command:
# ncc health_checks run_all
# ncc hardware_info show_hardware_info
# ncli host ls
# ncli ru ls
# ncli ms ls
# ncli cluster info
If we have a similar setup as yours, we shall try reproducing the issue internally and will release the fix ASAP.
  • 9 replies
  • February 12, 2020
NCC command:
# ncli host ls
# ncli ru ls
# ncli ms ls
# ncli cluster info
