Why doesn't my cvm have external_ip_reconfig | Nutanix Community
  • February 5, 2020
  • 2656 views
I’m trying to reconfig my ip addresses for the cvm but i cannot find the external_ip_reconfig script anywhere.
Do I have to download this from the site?
  • 18 replies
  • February 5, 2020
@johnnyb84
Script(executed by following command) can run once you log into the CVM. The script is in built
nutanix@cvm$ external_ip_reconfig
CHANGING THE CONTROLLER VM IP ADDRESSES IN YOUR NUTANIX CLUSTER (CLI SCRIPT
https://portal.nutanix.com/#/page/docs/details?targetId=Advanced-Admin-AOS-v5_16:ipc-cvm-ip-address-reconfigure-t.html
  1. What version of AOS you are using
  2. Have you tried running the above command ? if yes, did it run or gave any error ?
  • February 6, 2020
No i cannot run it and it’s not anywhere on any of my cvm. currently my nutanix system is a 2u brick because i can’t change the IP.
HITESH0801
  • 104 replies
  • February 6, 2020
Hey @johnnyb84
Can you give some information about your AOS version?
You can find the AOS version by running the command
ncli cluster info
And also share the output when you try to execute the command
  • February 6, 2020
Don’t worry I’ve managed to get it working using edit-zkmapping and edit-zeus commands.
