File server spec validation failed, unknown error - While Setting Up Files on Nutanix CE | Nutanix Community
  • January 31, 2020
  • 1895 views
nu.Florian
Hi all :)
i want to Setup a small Files on my nested (esxi) CE Enviorment for testing and Demo purposes.
I am able to install the Base Packages by modifing the json Metadata.
AFS Version tried so far: 2.2.4, 3.6.1, 3.6.1.1
AOS Version: 2019.02.11
Installation works without Problems.
But when i want to Setup the Server i get the following Error after completing the last Step in the Setup:
I allready give 12GB more RAM per Node to 60 GB/Node. And i checked all Netwoks, IPs, DCs, NTP-Servers and Gateways.
Besides the CVMs with 24 GB there is only one Windows VM running with 4GB RAM.
Has someone an Idea what this can be?
Jubran
  • 19 replies
  • February 5, 2020
Hi Florian,
Please ssh to a CVM to obtain the IP address of the uhura leader CVM:
links http://localhost:2037 --dump | grep -i "Uhura Master"
SSH to the IP address received from the command above and check the “data/logs/uhura.out” file, search for the timestamp of the error and look for this message:
“Unexpected error happened: vCenter connection could not be established”
This occurs when vCenter connection could not be established by Nutanix Files if the hypervisor is ESXi.
If this is the issue, then run:
genesis stop uhura ; cluster start
If the issue was not solved after this, consider contacting Nutanix support and we will check the logs to understand the root cause.
nu.Florian
  • February 6, 2020
Hi Jubran,
thanks for the Info. When i understand you right, then you need this when the Hypervisor is ESXI.
In my Szenario i install the CE nested on a ESXI. In the Nutanix Cluster itself i use AHV.
Will his fix den work also in my Szenario?
