Stargate continues to restart leaving node ....down | Nutanix Community
  • January 27, 2020
  • 1270 views
My stargate contimues to restart. and I cannot find anyting in the GUI to indicate what it my be.
When I get in the cli, i see the cluster says all four nodes are up.
i try to ping 192.168.5.1 and the icmp request never completes.
pinging all other ip’s work as expected.
my esx is 6.5u3
aos is 5..5.5
my NCC is 3.7.0.1
foundations is 4.3
Best answer by JeremyJ
This kind of thing I would generally suggest to open a case for. A single restart or once in a long while is not much of a concern but if it is happening frequently we should be actively addressing this through a support case if possible. The stargate.FATAL message gives some insight but not many of these are user-serviceable.
JeremyJ
  • 77 replies
  • February 19, 2020
