We want to throttle replication bandwidth.
In the Remote Site config in Data Protection, the option is to throttle B/W in MBps. Is this Mbps (megabits per second) or MB/s (Megabytes per second)? The unit implies megabytes per second (i.e. the "B" is capitalised), but that is normally a unit of throughput not bandwidth...
Obviously there is an order of magnitude in difference so its important we interpret this correctly!
Units used in Replication Throttling?
Best answer by Mutahir
AWatkins wrote:
The Network Bandwidth is displayed as MB/sec which is referred to as MegaBytes.
BR
