Recommended switch port buffer size | Nutanix Community
  • December 2, 2019
  • 2356 views
Is there a minimum or recommended switch port buffer size? I plan on using eth0 and eth 1 to be connected to two different 10G switches but was wondering if there is a minimum buffer size or switch port requirement?
  • 72 replies
  • December 2, 2019
Hi @David L.
You can read the AHV Networking best practices guide to better design your network infra for Nutanix HCI.
this is from the best practices guide above :
“To prevent packet loss from oversubscription, avoid switches that use a shared port-buffer architecture.”
we don’t have an exact port buffer size recommendation.
Normally with HCI and SDS deployments, it is good to use Line-rate, non-blocking switches with larger buffers for production workloads.Use an 802.3-2012 standards-compliant switch that has low latency, cut-through design and provides predictable, consistent traffic latency.
Hope this helps
BR
  • 111 replies
  • December 2, 2019
@David L. Most modern switches would not have any issues. But connecting to 10GB fabric extenders (FEX) is not recommended. See the link:
https://portal.nutanix.com/#/page/kbs/details?targetId=kA032000000TT4kCAG
If anything, you may occasionally need to change the buffer size for the Nics on the hyperviosr hardware side. Please review:
https://portal.nutanix.com/#/page/kbs/details?targetId=kA03200000099tuCAA
Based on document above, the number you look for might be 4096 bytes, but as I mentioned I would not change things on switch side, as I mentioned most switches should be able to handle the type of traffic hyper converged systems will generate.
-Said
  • December 2, 2019
Thank you!
