Is Nutanix working with the Container Storage Interface (CSI) community and Kubernetes in general? | Nutanix Community
  • December 12, 2017
  • 1780 views
Forum|alt.badge.img+25
Beyond simple docker volume support but can Nutanix bring their expertise into the CSI space to make orchestration systems like k8s aware of cluster wide storage resources?
It also leads into what Nuatnix is doing to enable a K8s API conformant solution on top of the platform. I recognize that we can layer on a k8s runtime as a customer, but similar to what we see with Pivotal leveraging BOSH to make day2 k8s work there seems to be demand for integrated options. The institutional storage knowledge could really take stateful sets to the next level and BOSH as a lot of similarities to Acropolis.
I know that there may be overlap with Calm when it comes to service orchestration, but k8s is becoming the defacto language for orchestrating an application delivered by containers.
Best answer by Akim
Hi @Dennis_Konrad . Did you got an answer about your RHEL support for AHV question ?
I'd like to clarify this:
RedHat is part of the Technical Support Alliance Network, like many vendors and editors. https://tsanet.org/members/
RedHat Support policy for third party platforms, hence running RHEL as guest OS on AHV, is pretty clear: They will provide you support according to your entitlement and if they think AHV is the root cause, they will get in contact with Nutanix through the Technical Support Alliance Network.
If you have any reason to think this is not working, or if you have found any document suggesting otherwise, please let us know.
If for any reason, you have any doubt when you need to open a case, you can open it at Nutanix who will help you sort it out, and get in contact with RH via TSANET if it's necessary, and work together with you and RedHat to help you.
Hope this clarifies the situation.
  • December 15, 2017
Short answer is, yes. 🙂 We have a Kubernetes Volume Plugin today using an External Provisioner (supported with K8s 1.6 and above) and investigating CSI. As you might already know CSI will is one of many alpha feature with the 1.9 release, so not ready for primetime. Today we have many customers running K8s distributions (CoreOS Tectonic, Red Hat OpenShift) on Nutanix so conformance is really on their end, but we do receive a lot of requests for a native K8s offering and when we release our offering conformance will be a necessity. We will leverage existing tools like LCM, etc to make day2 K8s ops easier. BOSH is actually similar to Calm, but purpose built for Cloud Foundry. Agreed, K8s is gaining a lot of momentum and is the defacto for Container Orchestration.
Sorry for reanimating this converstation but there is one question open for me:
What about RHEL support for AHV? Did the customers you menstioned just drop that? When using K8 it would be nice to have that as well.
aluciani
Forum|alt.badge.img+34
  • Chevalier
  • 348 replies
  • June 6, 2018
Hi @Dennis_Konrad
Let me see if I can get an answer for you 👍
  • March 7, 2019
