Hi, I have a query regarding the snapshot reference numbers in a replication alert I received recently. The error message is 'Replication was skipped for protection domain xxxx-Policy of snapshot (4779634355498612345, 1559835678912345, 75812345) to remote site xxxx-DR. Replication was skipped as a newer Recovery Point was available'. I understand the last number refers to the ID of the snapshot but what do the two longer numbers refer to? Many thanks.
Snapshot Replication Question
Best answer by Alona
The first value is snapshot cluster ID while the second one is cluster incarnation ID. Let me know if that helps.
